I inserted a bitmap image in a block.
But, I wanted to suppress of this bitmap image in the block. It seems that the bitmap image is persistant on my drawing, even if it's not in the block...
How can I suppress this bitmap image ?
In french... je suis plus à l'aise.
Dans un bloc j'ai inséré une image bitmap. Mais lorsque j'ai souhaité enlever l'image du bloc, il est bien partit du bloc mais est resté persistant sur mon dessin !
Merci !
Bitmap problem
Bitmap problem
- block.jpg (24.26 KiB) Viewed 7151 times
- zoom2.jpg (11.63 KiB) Viewed 7151 times
- zoom1.jpg (8.61 KiB) Viewed 7151 times
Debian Jessie - 64 bits KDE environnement
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Compiler : gcc 4.4.3
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Re: Bitmap problem
I would like to precise that this bimap image appear on the impression preview...
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
Re: Bitmap problem
I turn off the software and on. The bitmap does not appear!
Solved!
Solved!
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
QCAD Pro 3.9.1.0
Qt Verison : 4.8.4
