Help qcad
Moderators: andrew, J-J
CHHRIS 84
Help qcad
Post by CHHRIS 84 » Fri Jan 30, 2015 4:48 pm
Hi, I'm starting with quad, I have no problem with CE software if I draw a circle or arc no no and what the file and open with Autocad mayest hexagons circle and arc droites.Merci parties advance pay using your I remain at your disposal.
CHHRIS 84
registered member
Re: Help qcad
Post by andrew » Fri Jan 30, 2015 4:54 pm
Autocad approximates arcs and circles as polylines. You can improve the rendering quality by running the Autocad command regen.
CHHRIS 84
Re: Help qcad
Post by CHHRIS 84 » Fri Jan 30, 2015 5:19 pm
Thank you for your quick reponce c is nice, I draw made in steel parts which are then laser cutting j'm afraid that when the pieces are cut out holes or hexagons when you think of?
Re: Help qcad
Post by andrew » Fri Jan 30, 2015 5:26 pm
No need to worry. This approximation of Autocad only affects the display. Your drawing still contains the proper circles / arcs they are just displayed as polylines.
CHHRIS 84
Re: Help qcad
Post by CHHRIS 84 » Fri Jan 30, 2015 6:45 pm
Thank you again for your help so precious to me, m using to understand. J still have one last question, I have send both DXF files to my laser cutting company for a quote he m is said quotations n apparaissais not, when I open it with autocad ny had no dimensions it therefore had my any dimension with autocad .However, I am trying to draw a new project with laser etched and the odds appear much as I open the file with autocad .Avais you answer this? thank you has been great you good evening.
Faux ?
Moderator
Re: Help qcad
Post by Clive » Fri Jan 30, 2015 11:28 pm
CHHRIS 84 wrote:Thank you again for your help so precious to me, m using to understand. J still have one last question, I have send both DXF files to my laser cutting company for a quote he m is said quotations n apparaissais not, when I open it with autocad ny had no dimensions it therefore had my any dimension with autocad .However, I am trying to draw a new project with laser etched and the odds appear much as I open the file with autocad .Avais you answer this? thank you has been great you good evening.
Faux ?
Hi CHHRIS 84
This Google translation is difficult to understand, please repeat this post in your native French language, maybe J-J can help to translate or answer this.
Re: Help qcad
Post by andrew » Sat Jan 31, 2015 12:04 am
CHHRIS 84: you can also post your original French and the translation here. The original text is really important for accuracy. Thanks.
CHHRIS 84
Re: Help qcad
Post by CHHRIS 84 » Sat Jan 31, 2015 8:55 am
Bonjours tout le monde, une dernière question, j'ai envoyé un plan dessiner avec qcad à mon entreprise de découpe laser il y a quelque mois pour un devis,ils m ont repondu qu il n y avait pas de cotes sur le plan.Quand je les ouvert avec Autocad effectivement les cotes n'apparaissaient pas .Aujourd'hui j'ai refait un nouveau projet et là les cotes apparaissent bien .Avez-vous une idée a mon problème. Merci bonne journée.
CHHRIS 84
Re: Help qcad
Post by CHHRIS 84 » Sat Jan 31, 2015 8:56 am
Greetings everyone, one last question , I sent a plan qcad draw with my laser cutting business there a few months for an estimate , they m have replied that there were no odds on plan.Quand I Autocad actually opened with the ratings did not appear .Today I redid a new project and then the odds appear well .Avez you an idea my problem. Thank you good day.
CHHRIS 84
Re: Help qcad
Post by CHHRIS 84 » Sat Jan 31, 2015 9:06 am
Pour faire simple quand j ai envoyer mon fichier pour la découpe laser les mesures n y etait pas .
To make it simple when I have to send my file for laser cutting measures ny was not .
J-J
Moderator
Re: Help qcad
Post by J-J » Sat Jan 31, 2015 8:49 pm
Bonsoir Chris,
Je ne suis pas sûr que les cotes soient nécessaires au sous-traitant, toutes les dimensions sont incluses dans le dxf. Ceci dit, il faudrait avoir le fichier original qui présentait le défaut pour comprendre.
JJ Win7 pro-64
