QCAD 3.1 Beta Crash
QCAD 3.1 Beta Crash
Postby aladin » Mon May 27, 2013 9:07 pm
Hallo...
Vielen Dank erstmal, dass es QCAD 3.1 wieder als Community Edition gibt!!
Meine Umgebung:
Gentoo Linux gcc-4.6.3, glibc-2.15-r3, 3.8.13-gentoo x86_64 qt 4.8.4
Beim Testen bin ich, mit einer Datei die unter QCAD 2.0.5 erstellt wurde, auf folgenden Crash gestoßen:
Program received signal SIGSEGV, Segmentation fault.
0x00007f56948735a6 in RHatchData::addBoundary(QSharedPointer<RShape>) () from /opt/qcad/libqcadentity.so
(gdb) bt
#0  0x00007f56948735a6 in RHatchData::addBoundary(QSharedPointer<RShape>) () from /opt/qcad/libqcadentity.so
#1  0x00007f5683351dfc in RDxfImporter::addHatchEdge(DL_HatchEdgeData const&) () from /opt/qcad/plugins/libqcaddxf.so
#2  0x00007f568336809a in DL_Dxf::addHatch(DL_CreationInterface*) () from /opt/qcad/plugins/libqcaddxf.so
#3  0x00007f56833683bd in DL_Dxf::handleHatchData(DL_CreationInterface*) () from /opt/qcad/plugins/libqcaddxf.so
#4  0x00007f568336c686 in DL_Dxf::processDXFGroup(DL_CreationInterface*, int, std::string const&) () from /opt/qcad/plugins/libqcaddxf.so
#5  0x00007f568336cf41 in DL_Dxf::readDxfGroups(_IO_FILE*, DL_CreationInterface*) () from /opt/qcad/plugins/libqcaddxf.so
#6  0x00007f568336cf9e in DL_Dxf::in(std::string const&, DL_CreationInterface*) () from /opt/qcad/plugins/libqcaddxf.so
#7  0x00007f5683350b50 in RDxfImporter::importFile(QString const&, QString const&) () from /opt/qcad/plugins/libqcaddxf.so
#8  0x00007f56942b1ccd in RDocumentInterface::importFile(QString const&, QString const&, bool) () from /opt/qcad/libqcadcore.so
#9  0x00007f5694e1fd8a in REcmaDocumentInterface::importFile(QScriptContext*, QScriptEngine*) () from /opt/qcad/libqcadecmaapi.so
#10 0x00007f5692150ed5 in ?? () from /usr/lib64/qt4/libQtScript.so.4
#11 0x00007f5692069a60 in ?? () from /usr/lib64/qt4/libQtScript.so.4
#12 0x00007f5692040ce6 in ?? () from /usr/lib64/qt4/libQtScript.so.4
#13 0x00007f5602a48ae2 in ?? ()
#14 0x0000000000000000 in ?? ()
(gdb)
Hier die Datei die den Crash verursacht:
https : / / dl.dropboxusercontent.com/u/93717623/Funkturm.dxf.zip
Viele Grüße
Heiko
aladin
Re: QCAD 3.1 Beta Crash
Postby andrew » Mon May 27, 2013 10:46 pm
This should be fixed in the latest master branch.
Return to QCAD Professional
