I cannot login in my account
Have some feedback on the RibbonSoft web site? Want something added to the QCAD online manual? Post it here!
Postby Frank60 » Sun Apr 28, 2013 2:08 pm
I've been having trouble logging in in my account. I bought the software registering with a 25 character password, which was accepted by the software, since I could order and pay.... But when I later tried to login, the password was refused?!?
Then I reset the password and I could login again with the newly generated 8 character password.
But...when I changed this password on the website, it was refused again!!
This ahppened twice already. And I still cannot access the software in case of a re-download.
Not very reassuring...
I informed QCAD of this bug, but for the last three days nothing has changed.
I'd like to access the account and the software.
BTW: using a 25 character password on this forum has not created any problems.
Thanks,
Frank
Frank60
Re: I cannot login in my account
Postby andrew » Sun Apr 28, 2013 6:59 pm
Thanks for your report. I cannot reproduce that problem at the moment using a 25 character password. Perhaps the problem is something else? I can reproduce the behavior you have described with a password that contains spaces. I will report this issue to the makers of the shop software. For the meantime, please use a password that does not contain spaces, thanks.
Postby Frank60 » Sun Apr 28, 2013 7:08 pm
There were no spaces in the passwords.
These two I tried: [Y(rWa84H)]PSXqY+>9v:XVp& and aJG*FKv/jj{MF4KV%L&z(7^Z{
Frank60
Postby Frank60 » Mon Apr 29, 2013 6:18 am
Hallo..
What password can I use? Length, characters, special characters., lower case, upper case?
Frank60
Postby andrew » Mon Apr 29, 2013 9:16 am
I'd suggest a combination of lower case characters, upper case characters and numbers, length <30. It looks like the shop software can probably not handle anything more adventurous than that. Thanks.
Return to Site Feedback
