Changelog 3.6.1 - Save / restore relative zero point
Post by Husky » Fri Jul 18, 2014 6:46 pm
what means:
Misc:
Save / restore relative zero point position per tool
Could I get a short explanation? Thanks!
Re: Changelog 3.6.1 - Save / restore relative zero point
Post by andrew » Fri Jul 18, 2014 7:19 pm
Start the line tool.
Set the start point of the line.
Now start for example the circle tool and draw a circle (interrupting the workflow of the line tool).
The relative zero point is now at a position defined by the circle tool.
Terminate the circle tool (right-click) to return to the line tool.
Starting with QCAD 3.6.1, the relative zero point is now moved back to where it last was while using the line tool.
Post by Husky » Fri Jul 18, 2014 7:33 pm
How cool is that! Very convenient! :D
Thanks for explanation!
