Kubuntu 8.0.4 (heron) install
Postby coupedefleur » Sun Oct 12, 2008 2:48 am
Hi
I was running the community edition of qcad (loaded the binary via adept) and decided to buy the professional edition of qcad to get the polyline feature.
I think I had problems installing professional because of the already-installed community edition, so I deleted that (i.e. I uninstalled it).
What steps should I take to install my qcad tar.gz file? Is there an easy way to add it to my applications menu?
coupedefleur
Postby coupedefleur » Sun Oct 12, 2008 1:23 pm
After more messing around, I created a directory in /usr/local for qcad, copied the .tar.gz file there and unpacked it. I've can now run qcad as a desktop icon, but the hatch directory apparently isn't being found.
coupedefleur
Postby andrew » Mon Oct 13, 2008 9:24 am
You have to start QCAD from its installation directory, otherwise it cannot find its resources.
cd /path/to/qcad
./qcad
