editing rooms on a floor
Use this forum to ask questions about how to do things in vec2web.
Postby Obini » Wed Mar 10, 2010 3:19 pm
I need to change some of the rooms on a floor plan and then use a corrsponding shp-file in QGIS.
When I delete rooms, everythings works fine. However, if I add a room this is not registered in the shp-file. A clue: the added room stays red, while the lines of the floor plan are all in white. Do I somehow have to change the status of the new room (form red to white) before I save?
Grateful for any help!
Obini
Postby andrew » Sun Mar 14, 2010 6:50 pm
Could it be that you are in the wrong forum here? This forum is about QCAD, a generic 2d CAD, see http://www.ribbonsoft.com/qcad.html
Postby Obini » Mon Mar 15, 2010 6:48 am
I'm quite sure I'm in the right forum, as the question regards QCAD and its functions. My question was not very clear, though, due to my ignorance. Now, as I know more, I already have an answer.
Obini
Return to vec2web 'How Do I' Questions
