how do create a link with an external image
Postby AndyB78 » Mon Dec 06, 2010 1:52 pm
I tried to use the method "writeImageDef" but when I opened the dxf file with autocad the following error appears: "Unknown object type IMAGEDEF ignored".
Which are the correct step to do add a background image in a dxf file?
Thanks in advanced for your help.
AndyB78
Postby andrew » Mon Dec 06, 2010 10:01 pm
- Write the image definitions inside the OBJECTS section of the DXF file (see DL_Dxf::writeObjects / writeObjectsEnd).
- Write the image itself (writeImage) inside the ENTITIES section
