Scripting question, open template
hungerburg
Postby hungerburg » Thu Jun 16, 2011 8:38 pm
Before spending hours on what is bothering me now, I will just be bold and ask for a hint ;)
If in QCad2 I wanted to draw on a template, a single line of code was sufficient app.fileOpen("Vorlage.dxf");
I looked at the files in the script directory, there is of course a "load template" script. I wonder, how to wrap this into a function, that I can call in my own script as convenient as that one. Please share your ideas!
Regards
Peter
Postby andrew » Thu Jun 16, 2011 9:25 pm
Since a lot of the GUI part is implemented in ECMAScript (all MDI related things, how a document window looks like, scroll bars, rulers, etc.), you need to call that same script in order to get the same effect as when the user opens a file through the menu or tool button.
The script to open a file is located in scripts/File/Open/Open.js and can be used as follows in QCAD TP1:
include("scripts/File/Open/Open.js");
var action = new Open();
action.openFile("Vorlage.dxf");
action.finishEvent();
You might want to create a wrapper function for this, so it can be easily ported if the script API changes for the final QCAD version. Class 'Open' will be called 'OpenFile' in the next QCAD release since we had some problems with class names like 'Open' or 'New'. So the code above will change for QCAD TP2 to:
include("scripts/File/OpenFile/OpenFile.js");
var action = new OpenFile();
hungerburg
on the right track?
Postby hungerburg » Fri Jun 17, 2011 1:20 pm
I started with the wrapper. It currently looks like this:
include("scripts/File/Open/Open.js"); // TP2 // include("scripts/File/OpenFile/OpenFile.js");
 * Hilfsfunktion Vorlage öffnen, Namen der neuen Datei festlegen.
 * @constructor
 * @param {String} nameV Name/Pfad der Vorlage
 * @param {String} nameF Name/Pfad der neuen Datei
function Vorlage(nameV, nameF) {
   this.openFile(nameV);
   this.finishEvent();
   this.document.setFileName(nameF);
   this.mdiChild.setWindowTitle(nameF);
Vorlage.prototype = new Open(); // TP2 // Vorlage.prototype = new OpenFile();
I can use it from my code like this:
var Zeichnung = new Vorlage("Vorlage.dxf", "Zeichnung");
debugger; // inspect this
var operation = new RAddObjectsOperation(false);
var r = 10;
var off = 2 * Math.PI / 2000;
var c = 0;
for ( var a = 0.0; a < 2 * Math.PI; a += off) {
   var lineData = new RLineData(
      new RVector(Math.cos(a)*r, Math.sin(a)*r, 0),
      new RVector(Math.cos(a + off) * r, Math.sin(a + off) * r, 0)
   var line = new RLineEntity(Zeichnung.document, lineData);
   operation.addObject(line);
   ++c;
Zeichnung.documentInterface.applyOperation(operation);
The drawing functions are taken from simple.js in the samples directory. Notice that "new RLineEntity()" takes two parameters, unlike in the example.
Am I on the right track?
Postby andrew » Fri Jun 17, 2011 1:33 pm
Yes, that looks good.
A small detail: we always start class names with a capital letter and variable names with a small letter (e.g. 'var zeichnung = new Vorlage(...)').
hungerburg
Start from "New()"
Postby hungerburg » Fri Jun 17, 2011 2:11 pm
Will it be better to start from "New()" ?
include("scripts/File/New/New.js"); // TP2 // include("scripts/File/NewFile/NewFile.js");
 * @constructor
 * @param {String} template Name/Pfad zur Vorlage
 * @param {String} path Pfad der neuen Datei
 * @param {String} name Name der neuen Datei
function Vorlage(template, path, name) {
   New.prototype.beginEvent.call(this, false);
   if (this.documentInterface.importFile(template) != RDocumentInterface.IoErrorNoError) {
      var dlg = new QMessageBox(QMessageBox.Warning,
                          "Vorlage nicht gefunden",
                          "Vorlage nicht gefunden\n\n'%1'\n".arg(template),
                          QMessageBox.OK);
      dlg.exec();
      this.terminate();
      return;
   this.documentInterface.regenerateScenes();
   this.documentInterface.autoZoom();
   this.document.setFileName(path + "/" + name);
   this.mdiChild.setWindowTitle(name);
Vorlage.prototype = new New(); // TP2 // Vorlage.prototype = new NewFile();
When inspecting in the debugger I see that the object created from "Vorlage()" is of type "ActionAdaptor" - will that make problems?
(Peter Happy Hacking :)
Re: Start from "New()"
Postby andrew » Fri Jun 17, 2011 4:01 pm
hungerburg wrote:Will it be better to start from "New()" ?
In my opinion, both solutions are equally good. Opening a template is indeed somewhere between New and Open.
hungerburg wrote:When inspecting in the debugger I see that the object created from "Vorlage()" is of type "ActionAdaptor"
This is normal for all actions (tools). The complete inheritance hierarchy is:
RAction
RActionAdapter
EAction
New
Vorlage
The debugger calls the toString() function to display information about an object. toString() is implemented for all C++ class wrappers (classes starting with an R) to return the class name. Of course, you can also overwrite toString for your ECMAScript class, for example:
Vorlage.prototype.toString = function() {
   return 'Vorlage';
The debugger will then identify objects of that class with 'Vorlage'.
hungerburg
save template
Postby hungerburg » Fri Jun 17, 2011 6:42 pm
Thank you Andrew for your attentiveness. Slowly I am getting the knack:
Vorlage.prototype.save = function() {
    return new Save().save(this.document.getFileName());
Will save the file. Can I depend upon it, that this will be dxf? Is this determined by extension?
hungerburg
Re: Scripting question, open template
Postby hungerburg » Wed Aug 29, 2012 8:53 am
Sorry for waking up this old thread. Yet, the method in here, to programmatically open a template and use it as a base for further scripted drawing, got broken between release candidate 5 and qcad 3 final.
NewFile.prototype.beginEvent.call(this, false);
will no longer stuff the callers "this" with all the "documentInterface", "mdiChild" etc. properties.
As NewFile does quite a lot of initializations, I hesitate to reproduce all of its functionality in my own code, and would like to "inherit" again most of that.
Please advise, how in qcad 3, to open a template programmatically.
Thank You
Peter
hungerburg
Postby hungerburg » Wed Aug 29, 2012 9:56 am
Got it sorted out by looking at "NewFromTemplate":
NewFile.createMdiChild();
this.documentInterface = EAction.getDocumentInterface();
this.document = EAction.getDocument();
in place of "NewFile.prototype.beginEvent.call(this, false);" seems to do what I want.
Though I do not understand, why this works without passing some handles, it works flawlessly, creating several tabs in sequence, even from the same template.
Peter
Return to “QCAD 3 Developers and Contributors”
