Problem installing on Linux ('GLIBCXX_3.4.14' not found)
ambra
Postby ambra » Sat Aug 27, 2011 9:40 am
qcad-trial-bin requires gcc-4.4.4, but I have gcc-4.4.5, so QCAD fails to start.
QCAD should require major GCC versions (gcc-4.4.x), and not revisions.
Can this be fixed in final release?
Postby andrew » Sat Aug 27, 2011 1:22 pm
Deployment on Linux systems is certainly not straightforward and it will likely take a couple of iterations to get a binary that runs on most systems. It might even take multiple binaries / packages. We tried to cover the major distributions first (Ubuntu, OpenSUSE, Fedora). Other distributions will follow, in order of their popularity for desktop use.
Postby andrew » Sat Aug 27, 2011 1:24 pm
Discussion moved to bugtracker:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=205
FS#205 - fix gcc dependencies
Re: Problem installing on Linux ('GLIBCXX_3.4.14' not found)
Postby andrew » Fri Jul 27, 2012 1:14 pm
I've uploaded alternative packages for (X)Ubuntu 10.04, Debian 6 and some other Linux distributions which are not compatible with the regular QCAD packages.
Please check your download area for the packages called 'Linux (Alternative)' if you are using one of these distributions or the current packages show errors such as:
/usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found
Or:
I/O error : No such file or directory
/usr/share/mime/inode/directory.xml:1: parser error : Extra content at the end of the document
Return to “QCAD 3 Installation and Upgrades”
