Reloading of Script before execution
Postby hungerburg » Mon Sep 26, 2011 3:09 pm
Andrew, how do you do it, that a script gets reloaded from file on each execution?
The first custom script, the one that is called from the menu or button, will be reloaded each time, if the "beginEvent" hook ends with a "delete Foo" statement, Foo being the name of the class itself.
But classes instantiated inside of this class will not be reloaded the next time the first one is instantiated, and if I delete them, they will be missing then.
There must be a special trick that you apply and that I dont understand. Would you explain?
Peter
hungerburg
Senior Member
Postby andrew » Mon Sep 26, 2011 3:59 pm
We've introduced the command line option -always-load-scripts for this:
./qcad -always-load-scripts
See also output of:
./qcad -help
Deleting classes is no longer required with this switch.
QCAD3 rocks
Postby hungerburg » Tue Sep 27, 2011 9:57 am
Ahh, this is good news for people like me, that follow a very iterative approach to development - Thank You.
I tried now calling a script from commandline with the name specified for such occasions in the "beginEvent", but get this Warning: RGuiAction::getByScriptFile: no action found: "MyScript".
Using the path relative to the qcad3 root "scripts/..." works though. Using the -exec argument after a filename will even first load the file and then perform the action on it in one go. Great!
hungerburg
Senior Member
Re: QCAD3 rocks
Postby andrew » Wed Sep 28, 2011 12:21 pm
hungerburg wrote:I tried now calling a script from commandline with the name specified for such occasions in the "beginEvent", but get this Warning: RGuiAction::getByScriptFile: no action found: "MyScript".
The -exec switch expects an absolute or relative path to a script that contains a class with the same name as the file name and has a beginEvent function.
If I understand you correctly, you tried to pass -exec a class name. That is an interesting thought. Feature request:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=277
