Draw line tagent
Draw line tagent
Postby plgarcia » Sat May 19, 2012 9:00 am
It would be great to be able to draw tangents with ellips and not only with circle.
This would be really usefull for isometric projections as a circle is projected as a ellipse.
It is not a problem for cylindres projection as the tangent needed goes thew the reference point of the ellipse, but for a cone it is not the case.
Or there is a tric I did not found!
regards
plgarcia
Re: Draw line tagent
Postby andrew » Sat May 19, 2012 9:11 am
Tangents from points to ellipses should be possible with QCAD 3. Tangents between two ellipses are currently not supported.
Postby plgarcia » Sat May 19, 2012 2:23 pm
Thank you for this information. As I was trying to draw a trunc of a cone I was also trying to have a tangent of two ellipses. But if I project the top of the cone I should be able to contruct this tangent.
But I found now an other strange thing. I can construct a tangent to an ellips result of projection. But if the line starts at the end of a line that is the result of a projection, (the heigh of the cone) it does not work. Either the tangent goes to the center of the ellips or goes in an orthogonal direction or do not draw at all. It happens that this start point is also on the small axis of the ellips by construction.
So I construct an other point on this axis and got the same problem.
I did the same with an ellips directly drawn as (not a projection) and got the same problem.
The tangent to an ellips does not work if the start point is on an axis of the ellips.
Regards
plgarcia
Re: Draw line tangent
Postby Clive » Sat May 19, 2012 2:23 pm
I`ve added a 'workaround' tip which I have used successfully in the past.This may be useful until tangents between ellipses are supported.
See here:
viewtopic.php?f=47&t=2004
Postby plgarcia » Sat May 19, 2012 2:29 pm
Thank you, seems to be great.
For the cone I think it is better to solve the bug I found.
Regards
Pascal
plgarcia
Postby Clive » Sat May 19, 2012 3:31 pm
Feature request added:
To add support for drawing tangents between ellipses.
http://www.ribbonsoft.com/bugtracker/in ... ask_id=598
Postby plgarcia » Sat May 19, 2012 4:46 pm
That is great but there is a bug with the tangent between a point and an ellipse when the point is right on an axis of the ellipse.
I attatch a small test file. On this example there is no way to draw the tangent between the point A by contruction on the axis of the ellipse, and the ellipse. But you can draw the tangent going thow any other point not on the axis.
Regards
testTangentElipse.dxf
(40.26 KiB) Downloaded 323 times
plgarcia
Postby Clive » Sat May 19, 2012 6:15 pm
Hi
I see what you mean, the only workaround solutions for now are:
tangent problem.png (37.75 KiB) Viewed 6510 times
tangent problem 3.png (44.47 KiB) Viewed 6510 times
Postby plgarcia » Sat May 19, 2012 6:58 pm
Thank you for this workaround, it works.
Forget my problem, it is a bug that should be fixed. And it is very reproducable. The funny thing is that depending on the test I have had 3 different behaviours but all wrong. I beleave that there is an error in a formula : a limit case (a division by 0 for example) or a test (< instead of <=). I made some more tests and it seems it hapens only for the second axis and not for the first one.
Hope that will help.
Regards
plgarcia
Postby andrew » Sat May 19, 2012 7:05 pm
