[*Solved]Library Browser Error Installing 3.0 after Trial
Postby floodfill » Wed Jun 27, 2012 8:22 am
Hello, I have installed the QCAD 3.0 Trial version (Windows XP Pro) last week, bought and installed then the 3.0 RC5 (4.7.4) Full Version - uninstalled the Trial first.
Problem: the QCAD Library Browser still searches the library under /QCAD Professional Trial/library/... (directory was automatically properly deleted by uninstall routine).
Is there anywhere a config file for instance to change the settings? Thank you in advance, flood'
floodfill
Re: Library Browser Error Installing 3.0 full after Trial
Postby andrew » Wed Jun 27, 2012 9:26 am
floodfill:
You might simply be able to change the library browser path in the preferences of the library browser:
- start the library browser
- Edit - Preferences
- Remove the wrong path from the list of sources
- You can optionally add new paths but QCAD defaults to the library included with QCAD if nothing is configured
clive:
QCAD only uses the Registry to make the connection between .dxf / .dwg files and QCAD. All configuration is stored in .ini files.
Postby floodfill » Wed Jun 27, 2012 11:00 am
@andrew and @clive: Thank you, please mark problem as *solved*!
Used the solution by andrew. I have started the browser, waiting, holding down the enter key until the "errors" are gone and the QCAD Library Browser will open. Changed settings to new directory.
floodfill
