QCAD 3 Final
QCAD 3 Final
Postby Clive » Fri Jul 20, 2012 10:12 pm
Andrew
Well done and congratulations, after almost 4 years of planning and development you have now released QCAD 3 final, It is a very nice piece of work and a true reflection of all your hard work and my thanks goes to you and the Ribbonsoft team.
I particularly like the little added feature of the 'dock-able' view list for the Layer List, Block List, View List,Property Editor, Library Browser, Clipboard Display and the Command Line - such a very useful addition.
The Library Browser has been improved I see and the option to 'Create Library Item from selection' function is absolutely magic :wink:
Finally I must add that the 'start up' time seems a lot faster (to me anyway).
Regards
Re: QCAD 3 Final
Postby tukuyomi » Mon Jul 23, 2012 9:26 am
Ohh really nice release :D
Didn't see all the new features come in after the RC5, great surprises there :D
Is this a placebo effect or the boot time AND the UI are a lot faster too :) ?
tukuyomi
Re: QCAD 3 Final
Postby andrew » Fri Jul 27, 2012 1:12 pm
tukuyomi wrote:Is this a placebo effect or the boot time AND the UI are a lot faster too :) ?
Thanks, it might indeed run faster especially on machines with a slow hard drive as disk access for script files and other resources has been reduced to a minimum.
