Workaround Tip - Select entities by type
Postby Clive » Sat Jul 28, 2012 2:35 pm
Sometimes it is useful to select entities by type rather than by location or layer - the following is based on Andrews 'workaround' and a feature request has been added for this option to be added to the 'Selection Tools' tool set:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=630
select entities by type, 'workaround' 1.png (100.14 KiB) Viewed 6036 times
select entities by type, 'workaround' 2.png (106.07 KiB) Viewed 6036 times
select entities by type, 'workaround' 3.png (109.82 KiB) Viewed 6036 times
select entities by type, 'workaround' 4.png (90.5 KiB) Viewed 6036 times
Re: Workaround Tip - Select entities by type
Postby J-J » Sat Jul 28, 2012 6:38 pm
Hello Clive,
Smart idea, I tried it, quite useful indeed.
J-J
Moderator
Return to QCAD 3 Tips and Tutorials
