Trim Splines
Tiggr
Trim Splines
Postby Tiggr » Mon Oct 01, 2012 12:10 am
Hi!
I'm using QCAD 3.0 (I've paid for it, don't know, if there is still a community edition - and I realy like qcad for being easy to use).
Is there a way to trim a spline to a line?
I would like to trim the spline to the selected line...
Thank you for your help!
Bye
Tiggr (aka Marcus)
Re: Trim Splines
Postby Husky » Mon Oct 01, 2012 1:43 am
Make sure Line "B" is connected to your Spline "C".
Select Spline "C" and use the "Explode" Tool (Menue -> Modify) to convert the Spline into a Polyline.
Use a second time the "Explode" Tool to convert now this Polyline into a Line.
Now you can use the trim, break out, delete or what ever tools on this "Modified Spline.
Have Fun!
Tiggr
Re: Trim Splines
Postby Tiggr » Mon Oct 01, 2012 8:29 am
Hi!
Ah! Exploding two times! I've stopped after the first explode! :oops:
Thank you very much!
Bye
Tiggr (aka Marcus)
