Dimensions all show %, -1f
Postby RayArdia » Tue Oct 02, 2012 7:49 pm
Using ver 2.2.2.0 on Ubuntu 12.04.
Dimensions show their normal arrows etc but instead of the actual dim (in mm) they all show ' %, 1f'.
RayArdia
Re: Dimensions all show %, -1f
Postby andrew » Tue Oct 02, 2012 7:59 pm
Thanks for your report.
Please submit some follow-up information, to help us understand the problem:
Is this the case for newly created dimensions also or only for dimensions loaded from an existing file?
Was the file created with another CAD application?
What does the property editor show as property 'label' for such a dimension?
If this report applies to a particular file only, please attach or e-mail that file if possible.
Postby RayArdia » Tue Oct 02, 2012 8:26 pm
1.Is this the case for newly created dimensions also or only for dimensions loaded from an existing file?
For newly created dimensions. The file had no existing dimensions.
2.Was the file created with another CAD application? Yes, with LibreCAD.
3.What does the property editor show as property 'label' for such a dimension? Not sure what you mean by this, sorry!
4.If this report applies to a particular file only, please attach or e-mail that file if possible. File added.
Rabbit Hutch Details.dxf
(43.19 KiB) Downloaded 314 times
RayArdia
Postby Husky » Tue Oct 02, 2012 9:46 pm
@ Clive - I agree. And it has nothing to do with the OS - same behavior with windows ...
Work around:
Open this particular drawing in 2.2.2.
Select the entirety drawing and copy it into the clipboard.
Open a new drawing and paste this drawing.
Maybe you have now to adjust the Text size etc. but the big problem is vanished .... :wink:
Postby RayArdia » Tue Oct 02, 2012 10:35 pm
Thanks to you all for your help. The copying/pasting works fine, as you say some adjustments to fonts etc needed,but it WORKS :)
RayArdia
Postby Husky » Tue Oct 02, 2012 11:05 pm
Glad to hear that! :D
