3.03 hanging with some tools
Postby J-J » Tue Nov 13, 2012 7:56 am
I am trying 3.03 on the side and I noticed that the program hangs up with the parallel tools: the new line does not show unless you exit the tool, it also does not show the auto snap indicator, so you are not sure that the line is placed correctly.
Has anyone noticed that behavior?
Win 7-64
J-J
J-J
Moderator
Re: 3.03 hanging with some tools
Postby Husky » Tue Nov 13, 2012 8:41 am
J-J wrote:Has anyone noticed that behavior?
Win 7-64
Nope - no problems under XP 32
J-J wrote:...the new line does not show unless you exit the tool
Could it be that something is wrong with the color settings?
Exit -> Application Preferences -> Graphics view -> Colors ...
Postby andrew » Tue Nov 13, 2012 9:25 pm
I can reproduce the 'hang' which really means that the graphics view is not being updated as it should. I've filed a bug report at:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=716
I assume that the auto snap indicator not being displayed is the same issue (no graphics view updates in a certain state of the application).
Postby J-J » Tue Nov 13, 2012 10:30 pm
Yes, the autosnap is the logical following step of the tool.
JJ
J-J
Moderator
Postby andrew » Wed Nov 14, 2012 10:02 am
I've uploaded development snapshop QCAD 3.0.5 which should fix this problem. This is a Windows only release as this problem only occurs under Windows systems.
Please let me know if the problem persists.
Postby J-J » Wed Nov 14, 2012 1:47 pm
Thanks for the fix. I noticed the same thing with the grid...
J-J
Moderator
Postby andrew » Wed Nov 14, 2012 2:45 pm
Thanks clive. This was not totally unexpected. Unfortunately, there is no quick fix to these issues as they stem from an underlying library (Qt 4.8) which seems to be broken on Windows.
