Grid
Grid
Postby Frank60 » Thu Apr 25, 2013 1:56 pm
Hi
How do I move the grid behind the drawing lines?
Frank
Frank60
Re: Grid
Postby Frank60 » Thu Apr 25, 2013 3:15 pm
Hi
I mean that the grid lines conceal the lines of the object or shows in the middle of the lines if they have a certain size. The grid shows in front of the lines. If the lines are thin the grid lines conceal the object lines.
The grid shows as dots , so no problem, the meta grid shows as lines. I cannot turn off meta grid, so I'm stuck with the meta grid lines.
Frank
Frank60
Re: Grid
Postby andrew » Thu Apr 25, 2013 3:40 pm
Another possibility is to increase the transparency of the meta grid color:
In the preferences dialog, choose 'Others...' for the meta grid color. In the color dialog that pops up choose the color to be for example white and then increase the transparency as desired. If you are on a Mac, reduce 'Opacity' instead. If you are on Windows, reduce the 'Alpha channel'.
For most users, the meta grid lines are most useful if they are just barely visible. The ideal transparency setting depends on your preferred background color and monitor brightness / contrast settings.
Re: Grid
Postby Frank60 » Thu Apr 25, 2013 4:17 pm
Hi
Both solutions work fine, thank you.
Frank
Frank60
