QCAD 3.1 does not run on Windows 7 [solved]
Frank60
Postby Frank60 » Fri Jun 14, 2013 10:03 pm
I installed QCAD 3.1. On clicking QCAD in the startmenu the splash screen appears and disappears and then... nothing!
I managed to uninstall 3.1 and reinstall 3.0.
I'll wait with further updates until this has been solved.
Frank
Re: QCAD 3.1 does not run on Windows 7
Postby andrew » Sat Jun 15, 2013 10:03 am
This is probably due to a missing DLL on some systems. I'm working on a new package that should fix the problem. Thanks for your patience.
Postby andrew » Sun Jun 16, 2013 2:54 pm
A new package for QCAD 3.1 for Windows will be available in a couple of days.Thanks for your patience. For now, all Windows downloads refer to QCAD version 3.0 again.
Frank60
Postby Frank60 » Mon Jun 17, 2013 1:30 pm
OK, I will wait a few days.
Postby andrew » Mon Jun 17, 2013 3:42 pm
Frank: the new packages (3.1.1) are available now for download:
http://www.qcad.org/en/customer-area
