qCAD 3.1.3 info tools regression [solved]
Postby hungerburg » Wed Jul 03, 2013 12:55 pm
Just fetched qcad-3.1.3-pro-linux-x86_64.tar.gz and installed it. Everything fine, except the two info tools "i p" and "i e". angle etc. remain fine.
Clean installation, config wiped, still: start the application, select "i p" tool, on first click qcad hangs, with the empty drawing. Also it starts to eat memory, there must be a leak.
Actually, it doesnt hang, but gets so sluggish, only a little patience shows, the tools are working somehow, but the beam looks too big, does it? Screenshot attached.
Is it only with me, to see that? System is Ubuntu 12.04.
While memory leaking tool works sluggish as heck
hungerburg
Re: qCAD 3.1.3 info tools regression
Postby andrew » Wed Jul 03, 2013 1:02 pm
Postby andrew » Wed Jul 03, 2013 7:07 pm
This should be fixed in QCAD 3.1.4 (now available for download).
Postby hungerburg » Thu Jul 04, 2013 12:31 pm
Fix confirmed, Thank You Andrew
hungerburg
Users browsing this forum: Yahoo [Bot] and 4 guests
