3 point arc
3 point arc
Postby 30tooo » Thu Jul 18, 2013 10:02 am
How can I draw a 3 point arc tangentially from an arc say.... on the left , down to a line and then tangentially to one on the right ? You can see (hopefully my previous attempt and you should see that the circle on the left is not tangential with the arc. All help gratefully received . Thank you .
qcad question.tiff
qcad question.tiff (7.82 KiB) Viewed 4934 times
30tooo
Re: 3 point arc
Postby 30tooo » Thu Jul 18, 2013 5:19 pm
If you look at my picture you will see a line atvthe bottom. The was another parallel to that. That is a restriction. I used 3 point arc but if you look close you will see it is not tangential to the left circle. I thought i might be able to snap tangentially , snap to object ( the line) and the tangentially to the right circle.
I hope i have explained that ok.
Thanks for the reply.
30tooo
Re: 3 point arc
Postby 30tooo » Fri Jul 19, 2013 9:53 am
Thanks for being patient Clive . Maybe this might help you understand .
qcad 2.tiff
qcad 2.tiff (17.6 KiB) Viewed 4847 times
30tooo
Re: 3 point arc
Postby 30tooo » Fri Jul 19, 2013 4:41 pm
Thats the badger......
30tooo
Re: 3 point arc
Postby Husky » Fri Jul 19, 2013 5:44 pm
30tooo wrote:I thought i might be able to snap tangentially , snap to object ( the line) and the tangentially to the right circle.
Unfortunately that isn't possible in the moment - but I know that the developers are working on it for one of the next updates :wink:
Right now you have to work with construction / help lines to solve this challenge. 8)
Re: 3 point arc
Postby andrew » Wed Aug 07, 2013 5:20 pm
Yes, this should fit the bill.
BTW: The tool for this use case is called "3 Tangents" (not "Point, 2 Tangents"), I think the wrong tooltip might have been displayed in the screenshot above.
Re: 3 point arc
Postby andrew » Wed Aug 07, 2013 5:56 pm
I see.. which point did you choose then? Is the exact point on the line given or another point? I thought the circle touches the two other circles as well as the line.
Re: 3 point arc
Postby andrew » Thu Aug 08, 2013 10:55 am
clive wrote:I think Apollonius 'The Great Geometer' would have loved these circle tools.
Andrew you have done a fantastic job with these additional tools :D
Well, thanks :) It's a surprisingly complex problem. QCAD is using resizing and inversion to find the solutions.
Re: 3 point arc
Postby Husky » Thu Aug 08, 2013 7:26 pm
clive wrote:Andrew you have done a fantastic job with these additional tools :D
WOW - what a circle tool set!!! I have absolutely to agree with Clive - that is an extraordinary tool-set.
@Andrew:
My honest respect and compliment to you!!! Thank you very much to make the "CAD life" so easy for everybody!
