Imperial (US) drawing sheet templates, ANSI A-E
About the creation of DXF / DWG part library items.
Postby Husky » Sun Jul 28, 2013 9:06 pm
Hi guys - if you are in need of a couple "Imperial drawing sheet templates" - here we are :wink:
Well organized imperial Drawing sheets incl. Pr-defined Layers and Blocks for:
- Paper Frame,
- Title Block incl. Projection symbol 3rd angle (US),
- Zoned Border (Sub-Block of Paper Frame),
- Logo / Name (Sub-Block of Title Block - changeable!),
Drawing unit: inch
Linear Dimensions:
Dimension height: 1/8" (0.125 inch),
Format: Fractional, Precision: 1/32"
Scale 1"=1"
Easy to configure - visible/invisible how ever you like it,
Easy to copy/scale - everything on one Layer (Drawing sheet),
The "Drawing sheet" Layer is default locked - if you have to put Data into the Title Block you have to unlock the Layer ...
Imperial drawing sheet templates:
ANSI A / 28" x 11" Portrait,
ANSI A / 28" x 11" Landscape,
ANSI A.zip
(26.44 KiB) Downloaded 598 times
ANSI B / 11" x 17" Landscape,
ANSI C / 17" x 22" Landscape,
ANSI B+C.zip
(26.38 KiB) Downloaded 627 times
ANSI D / 22" x 34" Landscape,
ANSI E / 34" x 44" Landscape,
ANSI D+E.zip
(29.84 KiB) Downloaded 535 times
Projection symbols,
Projection symbols.dxf
(85.05 KiB) Downloaded 511 times
or ... at one go .zip ;-)
ANSI A-E.zip
(90.51 KiB) Downloaded 560 times
All downloads are free for QCAD user!
Customize it how ever you like it!
Have fun!!! 8)
Update: Imperial (US) drawing sheet templates, ANSI A-E
Postby Husky » Wed Sep 25, 2013 8:33 pm
Hey - how nice is that!
With the new QCAD 3.3.0 release we have more and nicer possibility's to handle i.e. the entries in a title blocks or a revision block.
It's called "Block attributes" and that was a reason for me to update the Drawing sheet templates with this new feature of QCAD.
QCAD 3 - Video Tutorial (Q&E).
"Drawing sheet template with block attributes"
Long story short:
You will find in the .zip the same Drawing sheet templates as above but now with the new block attribute function.
ANSI A-E with block attributes.zip
(101.52 KiB) Downloaded 556 times
Have fun! :wink:
Re: Imperial (US) drawing sheet templates, ANSI A-E
Postby BrushType4 » Mon Aug 03, 2015 9:36 pm
Hi, these are great. I would like to amend these to metric and United Kingdom standard paper sizes but I'm struggling to amend the templates successfully.
BrushType4
Postby Clive » Tue Aug 04, 2015 9:07 am
Hi , have a look here:
viewtopic.php?f=51&t=2047
They are also included with QCAD itself!
Postby BrushType4 » Tue Aug 04, 2015 1:53 pm
Thanks!
BrushType4
Return to Creating DXF/DWG items
