Crash - importing bmp
Postby dilasso » Wed Nov 06, 2013 2:38 pm
I try to import a bmp-file as a background of the drawing. But always when i try to import the file my qcad crashes.
I work an a kubuntu 13.04 platform.
Thanx for your help.
Roland
dilasso
Re: Crash - importing bmp
Postby andrew » Wed Nov 06, 2013 3:33 pm
Thanks for your report.
What is the exact type / format of the bitmap file (bmp, png, jpeg, ...)? Could you attach the file here is possible?
What version of QCAD are you using (Help - About QCAD)?
Postby dilasso » Thu Nov 07, 2013 10:01 am
The file I use is a bmp. see attachment)
The qcad version:
Version: 3.2.2.0 (3.2.2)
Build Date: Aug 21 2013
Qt Version: 4.8.4
Compiler: gcc 4.4.3
thanx for your help, Andrew!
dilasso
Postby andrew » Thu Nov 07, 2013 11:15 am
Thanks - I cannot find the attachment though. Please note that you have to click "Browse", select a file and then click "Add the file" to add an attachment to a post. Thanks again.
Postby dilasso » Thu Nov 07, 2013 11:34 am
Sorry, but it seams that it's not possible to upload files with the extension bmp here.
I successfully inported now a png-file into my drawing.
The bmp still failes.
Roland
dilasso
Postby andrew » Thu Nov 07, 2013 11:43 am
Yes, you're right. I've added bmp as accepted extension, so it should be possible now. Please accept my apologies for this hiccup.
Postby dilasso » Thu Nov 07, 2013 1:29 pm
Still having some issues with the upload. The file ist to big (5.7MB)
Sorry.
Maybe that's also an hint for the problems with the crash itself!
dilasso
Postby andrew » Thu Nov 07, 2013 1:36 pm
It could be.. Feel free to send it me by e-mail instead if you don't mind:
andrew [at] qcad [dot] org
Users browsing this forum: Yahoo [Bot] and 5 guests
