Feed Rate
jthornton
Feed Rate
Postby jthornton » Sun Nov 17, 2013 4:22 pm
I found this code in GCode.js but there is not an entry on the CAM Configuration page for feed rate.
GCode.prototype.getFeedrate = function() {
    return parseFloat(this.document.getVariable("Cam/Feedrate", 200));
JT
jthornton
Re: Feed Rate
Postby jthornton » Sun Nov 24, 2013 3:17 pm
Does anyone know where you put the feed rate?
JT
Return to “QCAD/CAM 3”
