Creating a tool that gets coordinates of selected object
Postby s4eed » Mon Nov 18, 2013 9:44 pm
Hi friends. Specially dear Andrew!
I need to create a new tool that extracts properties of selected object(x, y, width, height) and processes them and displays a result to the user. For example suppose this scenario :
1-User selects a car in his map ( opened in QCad )
2-User selects my tool(from toolbar or menubar)
3-(Here is the problem!) My tool gets x,y,w,h of selected car and produces a result based on these four numbers and displays a message box to the user.
I can create new tool (I've read this : http://www.qcad.org/doc/qcad/3.0/developer/_creating_new_tool.html!) But first of all I want to know whether it's possible doing such a task completely in Qt(processing the x,y,w,h numbers)?
Second I need a start point for how to do this task?
Thank you guys!
s4eed
Re: Creating a tool that gets coordinates of selected object
Postby andrew » Mon Nov 18, 2013 9:58 pm
You might want to have a look at the bounding box example which is very similar:
scripts/Misc/Examples/DrawExamples/ExDrawBoundingBox/ExDrawBoundingBox.js
(Online at: https://github.com/qcad/qcad/blob/master/scripts/Misc/Examples/DrawExamples/ExDrawBoundingBox/ExDrawBoundingBox.js)
This is no problem with the Qt / QCAD script environment.
Displaying a message box is as simple as:
QMessageBox.information(null, "Title", "My message...");
Postby s4eed » Mon Nov 18, 2013 10:10 pm
:D Really thank you ! But how can I create a tool completely in Qt.That's my problem, not showing a message :D . Is there any tutorial?
s4eed
Postby s4eed » Mon Nov 18, 2013 10:11 pm
Got It ! I can use every Qt classes in my .js file. Is it true?
s4eed
Postby andrew » Mon Nov 18, 2013 10:18 pm
Yes. Almost the entire Qt API is available in scripts. If you need help or an example for a particular class, just search through the scripts directory of QCAD - chances are there is already a script showing how to use that class somewhere.
Postby s4eed » Mon Nov 18, 2013 10:22 pm
I've never seen someone conscientious like you Andrew. Again thank you.
s4eed
