Window size for screen-casting - gone where?
Postby Clive » Thu Nov 28, 2013 2:31 pm
I can't seem to find the 'screen casting' window size in QCAD anymore - has it been taken off ?
It used to be under Main Menu > Misc > somewhere!
Re: Window size for screen-casting - gone where?
Postby Clive » Fri Nov 29, 2013 2:30 pm
Any news for this query ?
Postby andrew » Fri Nov 29, 2013 5:11 pm
The screen casting tool is highly experimental at this point and likely not working at all under Windows. What did you intend to use it for? Only to set the QCAD application window size?
Postby Clive » Fri Nov 29, 2013 9:29 pm
andrew wrote: Only to set the QCAD application window size?
Yes , that's all.
Postby Husky » Fri Nov 29, 2013 9:50 pm
Yes , that's all.
Will this work for you?
Sizer 3.34 is a freeware utility that allows you to resize any window to an exact, predefined size.
www_brianapps_net/sizer/
Postby Clive » Sat Nov 30, 2013 5:46 pm
Husky wrote:Will this work for you?
This may be okay, although it doesn't support 64 bits, it would be more convenient to use the option that was in QCAD before - albeit experimental!
@andrew, would it be possible to have a script to add to QCAD to change to the 'screen-casting' size that you included before, only for changing the size?
Postby andrew » Mon Dec 02, 2013 2:22 pm
I've added a separate simple example script, just for resizing.
It's also attached and can be installed by extracting the ZIP file into folder scripts/Misc/Examples/QtExamples of your QCAD installation.
You can also get it through github.com at:
https://github.com/qcad/qcad/tree/master/scripts/Misc/Examples/QtExamples/ExResizeWindow
The tool is accessible under Misc - Script Examples - Qt - Resize Window
ExResizeWindow.zip
(2.32 KiB) Downloaded 161 times
Postby Clive » Mon Dec 02, 2013 2:41 pm
andrew wrote:I've added a separate simple example script, just for resizing.
Great, thanks Andrew, I've just added it and it works a treat :wink:
