Tip-Selecting equal length lines with'Selection Filter' tool
Postby Clive » Fri Dec 06, 2013 1:11 pm
The new selection Filter tool available for QCAD pro 3.4.4 takes all the hassle out of selecting equal length lines :wink:
Here in my example I need to delete all lines of a certain length.
Selecting lines of equal length.png (19.08 KiB) Viewed 3534 times
Procedure
1. First select the line.
2. In the Property Editor highlight and copy the line length.
3. Open the selection filter (View > Selection Filter G,F) or click the button in the widgets set.
4. Set up the Selection Filter correctly:
Entity Type - Line
Property - Length
Comparison - =(equal to)
and in the Value field paste in the 'copied' length from the Property Editor.
6. Now click on the 'Add to current selection' button.
All the same equal length lines are now selected.
Selecting lines of equal length 2.png (5.81 KiB) Viewed 3534 times
Now I can delete/edit or modify them!
Job done :wink:
Re: Tip-Selecting equal length lines with'Selection Filter'
Postby andrew » Fri Dec 06, 2013 7:50 pm
Thanks! Always good to see how people are using features in sometimes unexpected ways :)
Return to QCAD 3 Tips and Tutorials
