Centreline Cross
riverbuoy
Centreline Cross
Postby riverbuoy » Sat Dec 14, 2013 7:11 pm
Centreline Cross
This tool draws a centreline cross in arcs, circles, ellipses and elliptical arcs, as requested by Husky and seconded by J-J.
In the options toolbar there are two input boxes labelled X and Y.
The value in the X box refers to the horizontal line of the cross, and the value in the Y box refers to the vertical line of the cross. If you leave the Y box empty then the value in the X box is used for both lines of the cross.
To the right of these boxes is a drop-down combo box with two options, 'Extend' and 'Length'.
Extend mode is equivalent to 'overshoot' in Husky's diagram. A positive value will extend the lines past the circle. A value of zero will draw the lines to meet the circle. A negative value will draw the lines short of the circle. If the length of a line evaluates to zero or less than zero, then that line is not drawn.
Length mode draws lines with the specified length in the X and Y boxes. Again, if Y is empty then X is used for both lines. Also if the length of a line evaluates to zero or less than zero then that line is not drawn.
To the right of this is the 'Orient' box. This specifies the angle to draw the cross at. You can enter a value between 0.0 (default) and 180.0. A value greater than 180 would be the same as that value minus 180. (i.e. 181 - 180 = 1, so 1 will produce the same result as 181. A value of 91 will not produce the same result if the lines are of a different length.).
Ellipses and elliptical arcs have an angle associated with them, so the cross is drawn at that angle. That angle becomes the base angle to which the orientation is added. (i.e. if an ellipse is drawn at an angle of 45 degrees, then the cross is drawn at 45 degrees. If you then set an orientation of 20 degrees, the cross will be drawn at 45+20 = 65 degrees.)
The lines are drawn on the current layer so they can have different attributes from the arcs, circles etc.
Also the command does not check if a cross has already been drawn, so if you click on a circle more than once then you will have more than one cross.
If you wish to undo a cross use the 'undo; option in the 'edit' menu. Right clicking terminates the command. If you select an entity that is not an arc, circle, ellipse or elliptical arc, then a warning message is shown.
The shortcut for this command is CS.
The attached zip file contains the 'Cross' sub-directory.
Extract this to the 'scripts/Misc/MiscDraw' sub-directory, and you'll find the command in menu 'Misc->Drawing'.
Hope this is what you requested. I have only done limited testing of this, but it appears to be working correctly. However if you do find a bug, let me know so I can fix it.
Cross.zip
(8.06 KiB) Downloaded 422 times
Re: Centreline Cross
Postby Husky » Sun Dec 15, 2013 2:25 am
riverbuoy wrote:Hope this is what you requested.
Yes - that is absolutely that what I was looking for. It's a kind of early Christmas gift for me ... thank you very much to work on this nice execution!!! :D :D :D
So far it works really well and the rotated etc. ellipse functionality is amazing!!! I will test this new tool a bit further and if I experience any bug etc ... :wink:
For now ... only one question: :oops:
Would it be possible to get an extra Button for this new function in the "Line Icon bar"? Yes I know: Dirt on me ... a whole scoop! :lol:
However - really well done! Thanks again!
J-J
Moderator
Postby J-J » Sun Dec 15, 2013 6:08 pm
Hello riverbuoy
riverbuoy wrote:Centreline Cross
It sure is, I love it, thanks again for sharing that handy addition.
JJ
riverbuoy
Postby riverbuoy » Sun Dec 15, 2013 8:40 pm
Hi Guys
I'm just happy to help.
Postby andrew » Mon Dec 16, 2013 2:08 pm
Thanks riverbuoy! This works great. I've added this tool to our repository for future QCAD releases.
I've only made one small modification to add the two center lines in one transaction, so the tool can be undone in one single step:
https://github.com/qcad/qcad/commit/eaf ... d4cc2b6482
riverbuoy
Postby riverbuoy » Tue Dec 17, 2013 12:49 am
Hi Andrew
Thanks for the tip. I am still fairly new to ECMAScript and QCAD's classes and methods, and frankly it hadn't occurred to me that you can add more than one entity in one operation. Thinking about it thought, it seems obvious that you could do this.
Anyway thanks again for the tip, and I'll keep it in mind for the future.
caigner
Postby caigner » Wed Jul 23, 2014 3:36 pm
I just saw that this script is already in the new version. Works really great! Thanks!
One more request: Would be nice to enter the extension (overshoot) also as a relative value in percent of circle diameter.
riverbuoy
Postby riverbuoy » Mon Jul 28, 2014 7:46 pm
caigner wrote:One more request: Would be nice to enter the extension (overshoot) also as a relative value in percent of circle diameter.
OK. Here it is. Replace the two existing files in '/scripts/Misc/MiscDraw/Cross' with the two attached files.
Enjoy
riverbuoy
Cross.ui
(3.68 KiB) Downloaded 179 times
Cross.js
(6.18 KiB) Downloaded 180 times
Postby Husky » Mon Jul 28, 2014 8:30 pm
riverbuoy wrote:Enjoy
I'll do that! 8)
Thank's! :D
Return to “QCAD 3 ' Script Add-On & Plug-in challenge ' - Work in Progress”
