Slovenian translation
Re: Slovenian translation
Postby miharix » Sun Jan 12, 2014 1:05 pm
Hi!
translation is now ready for GitHub.
I noticed that there are some parts especially under settings that aren't translatable. Is that correct?
miharix
Postby andrew » Sun Jan 12, 2014 1:18 pm
miharix wrote:translation is now ready for GitHub.
That's great news indeed!
miharix wrote:I noticed that there are some parts especially under settings that aren't translatable. Is that correct?
No, that shouldn't be the case. Do you have a specific example? Thanks.
Postby miharix » Sun Jan 12, 2014 1:42 pm
Here is Screen Capture of an example.
When I change language to any other is the same.
DE
SLO
miharix
Postby andrew » Sun Jan 12, 2014 2:36 pm
Thanks for the hint. I've fixed this in the current git master branch.
Postby andrew » Thu Feb 06, 2014 2:49 pm
I've finally had a chance to set up a translation server this week. So the Slovenian translation is now hosted at:
http://translate.qcad.org/sl/
Postby miharix » Thu Feb 06, 2014 3:29 pm
Wow a translation sever. I didn't know that such things exist. Impressive software!
I see that QCAD pro and QCAD/CAM are totally untranslated.
Are this so many additional strings? Because I looked a little on strings of QCAD pro and some do look familiar.
Ps: When do you plan to build the installer including Slovenian translation for http://qcad.org/en/qcad-downloads-trial
miharix
Postby andrew » Thu Feb 06, 2014 3:35 pm
miharix wrote:I see that QCAD pro and QCAD/CAM are totally untranslated.
Yes, these are two commercial / proprietary add-ons for QCAD.
Yes, there is likely some overlap as some QCAD Pro tools are based on simpler versions of the same tools contained in the free QCAD community edition.
The 3.4.6 release is work in progress. There is only one important bug fix pending at this point.
Postby Mirkoq » Sun Jun 14, 2015 7:31 pm
Is there any way to have commercial add-ons translated?
Mirkoq
Postby andrew » Mon Jun 15, 2015 1:47 pm
QCAD Professional can also be translated online at:
Please understand that we are relying on the QCAD community for translation into languages which are not officially supported. Currently officially supported are: English, German, French, Spanish, Portuguese.
QCAD/CAM is currently only translated into English and German.
Previous
