Shape of spline changes when importing DXF to Sketchup
Postby Azz131 » Mon Jan 20, 2014 11:32 am
I have done a drawing in Qcad i want it mirrored so they look the same both ends ... When i import it to Sketchup they look different
Azz131
Re: Qcad Importing to Sketchup
Postby Clive » Mon Jan 20, 2014 1:13 pm
Azz131 wrote:I have done a drawing in Qcad i want it mirrored so they look the same both ends ...
This can be achived in QCAD by using the Mirror tool - Main Menu > Modify > Mirror ...and follow the prompts.
Azz131 wrote: When i import it to Sketchup they look different
Sketchup is a 3D 'sketch' modelling program, in Sketch-up you can change the views to what plane you need i.e. Top view, side views etc.
Postby andrew » Mon Jan 20, 2014 7:20 pm
Azz131: Thanks for the screenshots. However, the DXF file would be more helpful for testing and helping you with the problem.
If I understand the problem correctly, only the spline at the right is rendered incorrectly by Sketchup. One simple solution would be to explode the splines in QCAD (Modify > Explode), then save again. This will convert the splines into polylines which are generally better understood by applications reading DXF files.
Postby Azz131 » Mon Jan 20, 2014 9:14 pm
I haven't got the file to hand tonight but i will post it tomorrow
Azz131
Postby Azz131 » Tue Jan 21, 2014 10:37 am
The dxf file is attached
Copings testing.dxf
(126.5 KiB) Downloaded 139 times
Azz131
Postby andrew » Tue Jan 21, 2014 12:46 pm
Thanks. I've filed a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1014
A workaround is also available (reconstructing the mirrored spline).
Re: Shape of spline changes when importing DXF to Sketchup
Postby Azz131 » Tue Jan 21, 2014 10:54 pm
Thank you >>> :lol:
Azz131
