Edit block
sramp
Edit block
Postby sramp » Fri Feb 21, 2014 12:43 pm
when I double click on a block the application goes in the edit block mode.
Please, is it possible to intercept this event?
I would like to avoid to edit the block.
sramp
Re: Edit block
Postby andrew » Sun Feb 23, 2014 12:02 pm
I don't have a good idea how to override that as easily as possible but the code is in DefaultAction.js in function DefaultAction.prototype.entityDoubleClicked. The default action could be made configurable in future versions.
sramp
Re: Edit block
Postby sramp » Sun Feb 23, 2014 5:51 pm
Andrew,
thank you very much.
It is exactly what I was looking for.
sramp
Return to “QCAD 3 Developers and Contributors”
