Hi all,
Currently working on a project and have run into an embarrassing issue.
The designer is sending a DWG that has 12-15 plates, however I can only see the first one in Q-Cad.
He showed me his file which has 15 tabs he can click through to view each drawing. I do not see anything nor having searched through the program have I come across a view list or tab list to see the additional pages.
Would anyone be able to help me understand if it is:
A) A Compatibility issue.
B) A User error issue.
C) A view selection issue.
Any thoughts are appreciated!
Josh
Auto Cad to QCad
Re: Auto Cad to QCad
The drawing is likely using paper spaces which is not currently supported by QCAD.
If you can attach or e-mail the drawing file, I can give you more detailed information.
Attached, please keep the information confidential.
Josh
[Admin edit: attachment CAP21_OTT-RENT_25MAR14_jjf.dwg deleted to keep it confidential]
Josh
Thanks. I've downloaded the file but removed the attachment from your post since you wish to keep it confidential and this is a public forum.
Hey,
Sure, I trust the people on the forum just wanted to be clear
Thank you!
Josh
Thank you!
Josh
