jpg images become delinked upon save and close
gregr
Postby gregr » Wed Apr 16, 2014 1:12 pm
Hi.
I have several jpgs inserted into a dxf file (QCAD 3.4.6). When I save, exit, and reopen the file, some of the image file locations have been lost. When I select the blank area where the image used to be, a blue handle appears; in the Property Editor pane, the File box is blank. I can paste in the file path and the image reappears. All inserted images are saved in the same folder and none of the images have been moved, renamed, etc. Only some of the inserted images lose their file location, but it is the same images every time I close and open the file.
Re: jpg images become delinked upon save and close
Postby andrew » Wed Apr 16, 2014 1:16 pm
Thanks for your report.
Please attach or e-mail the DXF and JPG files for testing. Thanks.
gregr
Postby gregr » Wed Apr 16, 2014 2:45 pm
Hi Andrew,
Thanks for your help. I am PM'ing you a link to the .dxf and images.
Postby andrew » Wed Apr 16, 2014 4:20 pm
I can only see two image entities in that drawing.
Generally speaking, I recommend to keep drawing files (DXF) and image files (JPG, ...) in the very same directory / folder. The DXF format does not support relative paths, but QCAD always tries to load images from the same directory if loading from the absolute path fails.
gregr
Postby gregr » Fri Apr 18, 2014 7:04 am
Hi Andrew,
Have you been able to reproduce the issue?
Postby andrew » Wed Apr 23, 2014 10:56 am
Greg: I haven't had a chance to try to reproduce this yet. Since you are using the community edition of QCAD, this might be a bug in dxflib.
