[RESOLVED] Add components from library bug ?
cfdev
Postby cfdev » Wed Apr 23, 2014 10:47 am
I have create some components and add them to an library, this is very simple, great work !
but when I try to insert them from library explorer... I can place some components but not all... why ?
In this example, I can't insert tIhe Interrupteur_double.dxf and PC_2P+T.dxf ????
here my components:
http://download.frausti.fr/Bibliotheque_dxf/
cfdev
Re: Add components from library bug ?
Postby cfdev » Wed Apr 23, 2014 5:41 pm
Opps sorry:
Version of Qcad 3.4.7 trial version (I hope to buy, if I can make electrical diagrams Architecturals)
OS: MSwidows 7 64bits
Postby Husky » Wed Apr 23, 2014 6:11 pm
cfdev wrote:In this example, I can't insert tIhe Interrupteur_double.dxf and PC_2P+T.dxf ????
you are working with invisible or locked layer? That could be one reason.
Postby andrew » Wed Apr 23, 2014 9:15 pm
cfdev: I can work with both parts just fine here. Can you insert these parts in a new, empty drawing? Perhaps a problem with your drawing file (PLAN_MAISON_.....)?
I've also noticed that you've arranged the toolbars in an unfortunate way. You cannot see all the options of the insertion tool:
There are more tool options available:
Screen Shot 2014-04-23 at 22.10.05.png (36.45 KiB) Viewed 3835 times
Note that for example setting the scale to a very small value or 0 might cause problems.
Another thing that comes to mind is the drawing unit. If your plan is in Meters and the part you insert is only 2 Millimeters wide (e.g. Interrupteur_double.dxf), it might simply end up being too small to be visible.
Finally, some of your items (e.g. "Lampe.dxf") contain a single block reference to a block called "Lampe". QCAD automatically creates a block with the same name as the file name ("Lampe") when inserting library items, thereby creating a recursive block (block "Lampe" contains a reference to "Lampe" = itself).
Part library items should contain plain entities. I.e. explode the block reference in Lampe.dxf and delete the block definition. Part library items should not contain any block references with the same name as the drawing file.
cfdev
Postby cfdev » Thu Apr 24, 2014 11:10 am
Idem on new drawing.
Ok for toolbar.
my drawing are in centimeter to make 1cm = 1m, Ok if all components can't insert into drawing but I'm able to insert some components.
Ok I remove All blocks in my libraries.
Postby andrew » Thu Apr 24, 2014 12:22 pm
I've downloaded all your parts and your drawing and the only two problems I can see are:
- Use of blocks in some items. Can be fixed by exploding the blocks.
- The file name "PC_2P+T.dxf" seems to cause problems. You can fix this by renaming the file to "PC_2P_T.dxf". I will look into that problem. [Edit: the problem here is that your drawing already contains a clock called 'PC_2P+T' which is empty. To overwrite this block, enable the tool option 'Overwrite blocks'].
On a side note: drawing in CAD are almost exclusively created in real size (1:1). That would mean to change the unit to meters in your case. A scale factor (e.g. 1:100) can then be applied when printing or exporting to PDF.
cfdev
Postby cfdev » Thu Apr 24, 2014 4:12 pm
Ok I fixe it
Ok
Second question, why I have this warning on save my drawing ?
Postby Clive » Fri Apr 25, 2014 8:41 am
cfdev wrote:Second question, why I have this warning on save my drawing ?
This shouldn't be too much to worry about, it is suggesting that you save the file to the latest revision - R27 (2013), it would be good practice to do this.
cfdev
Postby cfdev » Fri Apr 25, 2014 1:40 pm
humm Ok, if I don't saving the drawing on another file, Qcad doesn't change the original drawing.
now I saved it, on version 02.dxf and it's ok.
Many thx
Re: [RESOLVED] Add components from library bug ?
Postby Clive » Fri Apr 25, 2014 2:00 pm
You can of course save to 2000 dxf if you want to, it all depends on whether you share a file with someone else - if they use the latest format (R27) then it makes sense for you too to use it!
File formats are updated to introduce new features and general optimizations, like most things ... for example, next years new car model will have new features added to hopefully enhance it and make it better, the same with file formats.
dilasso
Postby dilasso » Wed May 07, 2014 8:32 am
Hi, i have a similar problem. Library elements are inserted very small.
My drawing unit is meter as i planning gardens. The plants i use from the library seem to be in mm, which actually makes no sense, but however, it is like this!
I tried to use a scale factor 1000 when inserting them. But the result was not satisfying.
What am i doing wrong?
Thanx for your help
Roland
Postby Clive » Wed May 07, 2014 8:55 am
dilasso wrote:I tried to use a scale factor 1000 when inserting them. But the result was not satisfying.
Hi Roland
When inserting your items type a scale of 1/1000 if working in meters, this should then work.
