Maximum arc length
Maximum arc length
Postby newinwit » Thu May 01, 2014 12:36 am
Dear Forum,
Does QCAD have a limit to the length of arcs?
I am having some trouble making qcad-pro draw very long arcs. Here is the situation: I draw a square with sides measuring, say, 2,000,000 units (inches). Then, using the Arc by 2 Points with Angle Tool, I use the mouse to draw a 90-degree arc from one corner to the opposite corner. The result: qcad starts to draw the arc, but the arc disappears midway to the other corner. I draw arcs just fine with dimensions under a million units. I am using QCAD 3.4.7 on Mac 10.6.8.
Sincerely,
-newinwit
newinwit
Re: Maximum arc length
Postby andrew » Thu May 01, 2014 11:14 am
Yes, I can confirm this limitation (max. arc radius is 1e6).
However, this limit to avoid slow rendering is no longer needed and has been removed for the next release.
Postby Clive » Thu May 01, 2014 12:19 pm
If it helps, for now as a workaround you can use the Ellipse tool.
Set Minor and Major axis.
Ellipse 1.png (2.81 KiB) Viewed 1738 times
Ellipse 2.png (4.07 KiB) Viewed 1738 times
Then Use the Divide tool, select first and second points and delete the part you don't need.
Ellipse 3.png (1.34 KiB) Viewed 1738 times
Postby newinwit » Thu May 01, 2014 1:42 pm
That explains it. Thanks for the quick reply, Andrew and Clive. I suppose I'll have to forgo the abstract doodling until the next release...
newinwit
Postby newinwit » Fri May 02, 2014 1:54 am
One more thing: Clive, your ellipse trick works like a charm. Thanks!
newinwit
