Info tool increments not evenly ...
Post by Husky » Fri May 02, 2014 8:47 am
If I use the Info tool with the option "Add measurement to drawing" I see that the increments not evenly spread on the mainline.
Is it a bug or did I missed some kind of control for this tool?
Test with a mm drawing:
Re: Info tool increments not evenly ...
Post by andrew » Fri May 02, 2014 9:45 am
Bug indeed!
Fix is available from:
https://raw.githubusercontent.com/qcad/ ... rmation.js
Replaces file scripts/Information/Information.js
Post by Husky » Fri May 02, 2014 5:59 pm
andrew wrote:Fix is available from ...
Works!!! Like always! :D
Thank you.
