Saving a bloc in library
Postby J-J » Fri Jan 20, 2012 10:36 pm
It is not possible to save a drawing in the library to make blocs for future usage as we did in 2.2.2.0 Is that feature reserved for final release?
Also, I have yet not found in QCAD3 the same convenient method existing in ver 2, to insert blocs from the library. The only option available is "open in file browser"...
system: Win7, 64 bits
J-J
Moderator
Re: Saving a bloc in library
Postby andrew » Sat Jan 21, 2012 8:43 am
J-J wrote:Also, I have yet not found in QCAD3 the same convenient method existing in ver 2, to insert blocs from the library. The only option available is "open in file browser"...
Drag the desired symbol from the library browser into the QCAD 3 drawing area to insert it as a block.
There is no insert button anymore for technical reasons: QCAD 3 and the QCAD 3 Library Browser are two separate applications and drag and drop is a convenient way to transfer data between two applications.
Win7 and block save
Postby J-J » Sat Jan 21, 2012 11:38 am
OK, thank for your answers, I'm not quite used to all the restrictions built in Win7, the permission change did the trick.
I had figured the drag-drop feature from the file browser, what would have been more convenient is having the blocks show directly in the library window when you develop the tree, rather than having to have to open Explorer.
J-J
Moderator
