how to create good quality wmf files from cadd files??????
Postby rasheedck » Wed Mar 28, 2012 10:41 am
Pl. let me know how to create good quality wmf files from dwg files or dxf files ??
The final output file ie. *.wmf file should not alter the shape of the drawing or text in the drawing when it zoomed .
This is very much required to do with the EpaNet software for doing the Water distribution network analysis
Kindly help
Ahamed
rasheedck
Postby andrew » Thu Mar 29, 2012 9:10 am
QCAD does not produce WFM files. The best option is likely to create an SVG file with QCAD and convert that to WMF for example with Inkscape.
Re: how to create good quality wmf files from cadd files????
Postby rasheedck » Fri Mar 30, 2012 11:13 am
How ???
Pl. let me know how it can be accomplished ........
Thanking
Rasheed
rasheedck
Postby hungerburg » Fri Mar 30, 2012 12:18 pm
There may be programs to directly get you wmf from cad. Not that I know of though. There are several to get you wmf from svg. QCAD dwg/dxf CAD to SVG conversion is best of breed. UniConverter should be as good as you can get for wmf creation. For download and usage instructions refer to http://www.sk1project.org/modules.php?n ... iconvertor - Possibly, also the latest LibreOffice can read svg and write wmf.
hungerburg
