[solved] Hatch solid fill color
Please use this forum to post feedback and suggestions related to QCAD version 3
Postby liderbug » Wed Oct 24, 2012 4:06 pm
I'd wag someone else has ... but my searching can't find.
Confusion: I select an item, click Hatch-Solid = black. But my color is red. How do I change from black to red - hello Google? Turns out just go ahead had fill. It's the Hatch solid vs pattern box that lies (leads one astray). Seems the Hatch-Solid 'display' is always black but draws 'color'.
Then foreground/background works, yahoo...
Now a question - is there a way to (because my printer is B/W) have a border color (black) and a different fill color (white)? That way hidden lines would hide.
Thanks - Great program.
Chuck
liderbug
Re: Hatch solid fill color
Postby gwood » Sun Jul 24, 2016 5:15 pm
Hmmm, this post was from 2012 and never got an answer. Is this forum active?
To answer the OP's question (what I THINK he's asking, anyway), I always use a separate layer for my fills. I set the color at the layer level. Then, all my fills/hatches will be that color. This works very well in that if you decide to change the color later, simply edit the layer, change the color in one spot, and every fill contained by that layer automatically changes color.
Now a question of my own, related to the OP's question:
I would like to effectively crop an inserted graphic, by using rectangles which are filled with WHITE. This should be easy-- draw the rectangles in the places I want white to appear, then be sure the graphic is "behind" the rectangles. Trouble is, the white rectangles show up black, instead of white. Is there a way around this?
I'm using the pro version, 3.1.2.0.
Thanks.
gwood
Postby Husky » Sun Jul 24, 2016 5:44 pm
gwood wrote:Trouble is, the white rectangles show up black, instead of white. Is there a way around this?
Hi gwood,
I don't know your Background color but maybe this effect is based to the "Color Adjustment" settings.
Please check your "Prevent white on white / black on black display" settings.
Solved: (Re: Hatch solid fill color)
Postby gwood » Sun Jul 24, 2016 7:00 pm
Husky,
Using your tip, I was able to solve my problem. Thank you. You may consider this question SOLVED.
As an aside, changing this color adjustment setting reveals a strange interaction between the graphical display, and the print-preview display. To wit: I use a black background in my graphical display, and with this setting unchecked, I am unable to see black lines (which normally display as white). It's not a big deal, I just have to re-check the color adjustment box after I do my print.
Ideally it seems it would be nice to have greater separation between the graphical display, and the print-preview display. Maybe that's already been done in a newer version? I haven't upgraded in a good while.
Thanks again for your quick reply.
gwood
Re: Solved: (Re: Hatch solid fill color)
Postby Husky » Sun Jul 24, 2016 10:12 pm
gwood wrote:To wit: I use a black background in my graphical display, and with this setting unchecked, I am unable to see black lines (which normally display as white). It's not a big deal, I just have to re-check the color adjustment box after I do my print.
Launch the "Print Preview", switch to the "Black/White Mode" in the Options bar and all your lines are visible ...
... no need to toggle always this setting in "Application Preferences" :wink:
Postby gwood » Mon Jul 25, 2016 2:51 am
The Black/White button makes all my lines visible, but it also gives me a monochrome print (no color). The other setting did exactly what I needed though. Thanks again.
gwood
Return to QCAD 3 Suggestions and Feedback
Users browsing this forum: Bing [Bot] and 1 guest
cron
