thin space
thin space
Postby Surendranath » Mon Jan 07, 2013 11:02 am
How do i type in a thin space between characters? I need this thin space between the value and the unit of a quantity like in "1 mm". The normal space character feels a bit too wide for this purpose.
Thanks,
Surendranath
Surendranath
Re: thin space
Postby Husky » Tue Jan 08, 2013 2:23 am
Hi Surendranath - welcome in the Forum!
Honestly - I don't know how you could do that on a normal way in QCAD but if you have only a couple values to edit then you could work with different sizes of Font Heights.
Screenshot:
What you can see in the first line is a continuous Text Height of 1 (your problem case :wink: ),
The second line is also with a Text Height of 1 - EXCEPT the space between the characters. The empty space has a Text Height of 0.25!
This is not really a nice solution but in a case of need ... :roll:
@Admin, Moderator
1 mm with a "Short space" is the correct spelling! Provides QCAD a "Short space" and I just don't know it? 8)
Re: thin space
Postby Husky » Tue Jan 08, 2013 11:24 pm
clive wrote:
Husky wrote:1 mm with a "Short space" is the correct spelling! Provides QCAD a "Short space" and I just don't know it? 8)
Not sure I know what you mean Husky - explain some more.
SI (International System of Units) says:
The value of a quantity has to be written as a number followed by a space and a unit symbol; e.g. "51.47 kg".
The space is representing a multiplication sign!
A unbreakable or short (unbreakable) space has to be used to keep the number and unit together in Computer programs - e.g. in Word at the end of a line ...
Hihi - that was never a problem with a typewriter ... :lol:
Re: thin space
Postby Surendranath » Wed Jan 09, 2013 6:40 am
This is a workaround.
1\S^ ;mm
I have used subscript option to get the result
Surendranath
