How do I lengthen the dimension line?
Postby caigner » Mon Apr 22, 2013 7:45 pm
I added a diametric dimension to a circle and wanted to move the number outside the circle. Moving the number was no problem, but the line of the diametric dimension did not "grow" with the moved dimension text.
So here is my question: How do I lengthen the dimension line?
caigner
Re: How do I lengthen the dimension line?
Postby Husky » Tue Apr 23, 2013 7:14 am
Hi caigner,
in this case you have to explode the dimension - then you can use the lengthen tool. I think this is just a workaround - but I can't see right now a better solution.
Maybe worth a feature request ..... :wink:
Postby caigner » Sat Apr 27, 2013 6:14 pm
Thanks! Works well enough. But you are right, it will be a great feature. :-)
caigner
