100% cpu snap intersection
Postby archon » Wed Aug 21, 2013 2:50 pm
I consider buying qcad pro, but first i wanted to try it out. I downloaded latest trial version 3.2.1 for linux 64bit. I am running slackware 14 64bit on lenovo notebook with amd Iliano apu. When I use autosnap (with snap intersection) or snap intersection alone with any tool, qcad freezes with 100% cpu use. Time needed for things to come back to normal is longer when there is more snap points around the pointer, but normally is about 5 to 10 seconds. I searched bug tracker but found nothing. What could be the problem? Thanks
archon
Re: 100% cpu snap intersection
Postby andrew » Wed Aug 21, 2013 2:54 pm
Thanks for the report. Can you submit the drawing file for testing (you can attach it to your post or e-mail it to me if it is not for the general public). Thanks.
Postby archon » Wed Aug 21, 2013 3:45 pm
Here it is
edit:
I've made some testing with other drawing in dxf, house project, definately bigger one and the problem was present only on the signature on the bottom. So i thought about text and deleted all text (from the file I attached)- the problem is gone.
Untitled12.dxf
(54.95 KiB) Downloaded 185 times
archon
Postby andrew » Thu Aug 22, 2013 11:58 am
clive: OK, thanks for confirming that.
