Does not show up any drawing
Postby bilal » Fri Aug 23, 2013 12:40 am
I am using QCad 3.2.2 Pro. I came across a situation where some files does not open up properly.
CNC Machine and Drilling Machine properly opens up on LibreCad properly. Please look into it.
There are other files with similar issue as well, i am sharing 3 of them with you and can be downloaded from the link
dropbox.com/sh/8smb84lupkgyp39/sKBN9pyv49
bilal
Re: Does not show up any drawing
Postby Ferdi » Fri Aug 23, 2013 9:55 am
Hi clive
try www.dropbox.com/sh/8smb84lupkgyp39/sKBN9pyv49
Ferdi
Postby andrew » Fri Aug 23, 2013 11:59 am
clive: you'd have to enter the URL in the browser. Search engines won't find URLs that are not referenced from anywhere.
Ferdi: I've white-listed dropbox now for forum links:
http://www.dropbox.com/sh/8smb84lupkgyp39/sKBN9pyv49
I can reproduce the problem here. It seems to be caused by the way how polylines and vertices are stored. This will likely be fixed in the next release.
Bug report:
http://www.qcad.org/bugtracker/index.ph ... ask_id=903
Postby bilal » Fri Aug 23, 2013 12:42 pm
Thanks Andrew looking forward to that meanwhile please look into the attached drawing as well.
Could be the same issue, but you can check.
budweiser2013.dwg
(597.03 KiB) Downloaded 185 times
bilal
Postby bilal » Sun Oct 06, 2013 8:51 pm
Not fixed in 3.3.3?
bilal
Postby andrew » Sun Oct 06, 2013 9:03 pm
bilal: The issue with the files from dropbox has been fixed.
The budweiser2013.dwg file contains a lot of 'tests' using advanced DXF/DWG features which are simply not supported by QCAD at this point (and won't be anytime soon). This is not a bug but a deliberate feature limitation to keep QCAD simple and development goals realistic.
If there is a specific issue, you would like to be addressed, please let me know so I can tell you more about the likelihood of that getting implemented.
