[SOLVED] How do I rotate the coordinate system?
Postby pbergaus » Mon Jun 23, 2014 7:20 pm
is it possible to rotate the whole coordinate system?
I want to draw the four views of a building, based on the ground plan, which is placed above the view for easy constructing. Now I would rotate the whole drawing in 90 degree steps to achieve that.
Is there (another) way to get that result?
pbergaus
(openSuse 13.1; QCad 3.6.0 64bit)
QCad: 3.9.1
Linux Mint: 17.1. Rebecca
pbergaus
Re: How do I rotate the coordinate system?
Postby Husky » Mon Jun 23, 2014 8:15 pm
pbergaus wrote:...is it possible to rotate the whole coordinate system?
No, not that I know.
pbergaus wrote:Is there (another) way to get that result?
Yes, select all - use the "Rotate" tool. Rotate 90°. Done :wink:
Postby pbergaus » Mon Jun 23, 2014 8:58 pm
Yeah, okay. I did that already :)
Thanks ;-)
pbergaus
QCad: 3.9.1
pbergaus
Users browsing this forum: Bing [Bot] and 4 guests
cron
