Setting Preferences
Setting Preferences
Postby scot6puk » Wed Jul 23, 2014 2:53 pm
I want to set the preferences to Feet as I want to work in feet and inches. I tried to set it in application window but it doesn't change. Is there a way to set it so when I load the programme it loads?
scot6puk
Re: Setting Preferences
Postby andrew » Wed Jul 23, 2014 6:11 pm
The unit you define under
Edit > Application Preferences > Defaults for New Drawings > Drawing Unit
applies to new drawings created with File > New
The unit you set under
Edit > Drawing Preferences > General > Drawing Unit
applies to the current drawing document.
When working with feet and inches, you'll most likely want to set the drawing unit to inches and display dimensions as feet and inches:
Screen Shot 2014-07-23 at 19.09.00.png (63.17 KiB) Viewed 2014 times
Drawing Preferences > Dimension > Dimension Settings
Screen Shot 2014-07-23 at 19.09.17.png (98.95 KiB) Viewed 2014 times
Postby scot6puk » Wed Jul 23, 2014 6:39 pm
andrew wrote:The unit you define under
Hi Andrew, I am using 3.6.2 on windows 7 and my programme only shows some of this and both Preferences are set to inches neither one shows this when I load a new programme or when I start it again and the apply button does not do anything, will I need to reinstall Qcad again?
Len
scot6puk
Postby andrew » Wed Jul 23, 2014 7:01 pm
Can you please double-check the version under Help > About and probably post some screenshots? You should definitely have all these options in QCAD 3.6.2 (the latest version).
Postby scot6puk » Wed Jul 23, 2014 7:46 pm
It's definitely 3.6.2, how do I do screenshots on my laptop?
Len
scot6puk
Postby scot6puk » Wed Jul 23, 2014 10:29 pm
Here are the snips. None of the Apply buttons work.
Len
scot6puk
Postby scot6puk » Wed Jul 23, 2014 11:05 pm
Hi Clive I think I have found what it was, I needed to change settings to Engineering (Doh). Thanks for all your help, and you taught me to do screen capture :D
Len
scot6puk
cron
