Shift Key= Orthagonally Constrained (Solved)
This forum is a place where people can cast their vote for feature requests to be implemented from a selection of the top favorites submitted to the 'Bug tracker':
http://www.ribbonsoft.com/bugtracker/.
seasdes
Post by seasdes » Sat Jun 05, 2021 8:42 am
I would like to have a feature where if you pressed the Shift key during an operation the cursor would act orthoganally.
This is a feature common to a lot of graphics/ CAD packages. Would certainly speed up operations.
I know that there are features similar to this in toolbars. What I am requesting would not replace these commands.
Seasdes
QCAD Pro V3.26.4
User since 2021
W10
Re: Shift Key= Orthagonally Constrained
Post by andrew » Sat Jun 05, 2021 9:00 am
In QCAD you can use the Alt or Option key for this.
Shift is used to move the start or endpoint of a line without changing its angle (extending / shortening).
seasdes
Post by seasdes » Sat Jun 05, 2021 9:15 am
Great news Andrew
Seasdes
QCAD Pro V3.26.4
User since 2021
W10
Return to “QCAD Voting Corner”
