QCAD 3.7.1
Posted: Fri Nov 07, 2014 11:02 am
QCAD 3.7.1 is now available. This release improves the presentation of the linetype choice and fixes a bug in with linetype pattern scales. Changes to some document settings are now undoable (e.g. unit change, linetype scale change, change of dimension settings, etc.). Spline support is no longer limited to degrees 1, 2 and 3.
A complete change log is available at:
http://www.qcad.org/en/qcad-documentati ... -changelog
Update instructions for QCAD Pro users can be found at:
http://www.qcad.org/en/customer-area
