QCAD 3.17.2
Announcements of new QCAD Versions, Updates, new Documentation, ... Please refer also to the RibbonSoft web site.
Locked
QCAD 3.17.2
Post by andrew » Tue Jun 27, 2017 2:18 pm
QCAD 3.17.2 adds new alternative projection types to the isometric projection tool. Multiline texts and formatted complex texts are now exploded into single line, simple texts. SVG export of multi-line and formatted texts has been improved. A new tool to copy (duplicate) blocks has been added.
The QCAD command line tools dwg2bmp, dwg2pdf, dwg2svg and dwg2maptiles come with a new -layer switch to export a given set of layers only.
QCAD/CAM 3.17.2 adds new post processors for EMC2 and Mach3 controllers.
A complete change log is available at:
http://www.qcad.org/en/changelog
Update instructions for QCAD Pro or QCAD/CAM users can be found at:
http://www.qcad.org/en/customer-area
Locked
Return to “Announcements”
