i try yo generate a pdf file from the attached dwg file but it generates blank pdf. The dwg file is large.
I tried different optinos like this:
dwg2pdf.bat -o c:\11.pdf block="*Model_Space" -paper=17780x1270 -pdf-version=1.6 -force -a -c c:\1.dwg
Blank PDF from dwg2pdf
vd9
- Registered Member
Re: Blank PDF from dwg2pdf
May I remark that the lower left corner of your content is about at (529928, 4514000)
And that the page settings specifies a viewport at (0, 0) or not configured and in default values.
This would not matter for the command line tool with the -a -c flags
BTW: It is never a good idea to draw that far form the origin.
Number accuracy reduces because of the limited decimal digits (15-16) in the Floating Point system.
Other remarkable things:
- The design is only 29 by 421mm for all 12 page representations.
- A paper of 17780x1270 in paper units or about 18 meters wide and more than 1 meter high ... Truly landscape
- Navigating in full view is rather sluggish, exploding all (stacked) blocks results in >54k drawing entities.
Over 500 Hatch entities with over 110k line segments to render.
Not really a simple drawing file.
I can get a decent output with:
The margins might have been the problem.
The resulting PDF file is 20MB and too large to be attached here. My PDF viewer also struggles to load the file.
dwg2pdf -auto-fit -margin=0 -force -paper=17780x1270 -pdf-version=1.6 -o 1.pdf 1.dwgThe resulting PDF file is 20MB and too large to be attached here. My PDF viewer also struggles to load the file.
vd9
- Registered Member
Thank you very much for your detailed explanations; I truly appreciate your help.
I need to convert very wide DWG files to PDF, and struggling to find a solution. I have even larger DWG files in the queue
I tried Andrew's command as follows:
dwg2pdf.bat -auto-fit -margin=0 -force -paper=17780x1270 -pdf-version=1.6 -o e:\11.pdf e:\1.dwg
However, it generates a blank 2KB PDF file (attached). I have also included the command-line output for reference.
I am currently testing using the trial version and have attempted this on two different Windows computers, but the issue persists. I would appreciate any insights you might have on resolving this.
Would already be a problem for rendering some Hatch entities.
26 warnings in total.
I presume that this is related to ellipse methods and those are found to be inaccurate in some occasions.
At some point the methods may fail for a fixed tolerance even when that is unnecessary tolerant.
Not that these issues can be fixed easily, ellipses are a little mathematical nightmare.
Some problems have no closed-form solution and can only be solved with elliptic integrals.
Referring to:
Coordinate values will decrease drastically for the integer part, leaving more room for higher accuracy.
As result: All will be mathematically more stable.
But it can also be the overall scale of your design
Very tiny arcs may already have parameters very close to some fixed tolerance level.
For the record: Per direct I am unable to find ellipse arcs in Hatch loops.
Therefor I isolated all Hatches as solid, exploding them to outlines.
What resulted in Arcs (389) and Lines (3030) but no Ellipse Arcs.
It is possible that these ellipses were nearly circular and were replaced by Arcs during the explosion process.
Also found a problematic use of the Hatch pattern 'GRAVEL'.
This is a badly coded standard pattern that can't be stretched that far.
Not for the QCAD Hatch rendering engine.
Standard advice is to keep your Hatching origin near the hatch.
Typically the Hatching origin is (0, 0) for all included Hatches what is pretty far from where the Hatches occur.
RHatchData::getBoundaryPath: loop not closed: ellipse arc does not connect26 warnings in total.
Referring to:
A simple solution might be to move the entire design closer to the origin.
